Sharing a Saved Item
You can share items using a memory card.
  1. From the Saved app, select the item you want to share.
  2. Select an option:
    • To share a route or track, select Wrench icon > Share.
    • To share a waypoint, select Share.
  3. Select an option:
    • To save the item to a memory card, select Memory Card.
    • To save the item to a memory card as a Lowrance compatible GPX file, enable the Lowrance Compatible GPX File option, and select Memory Card.
  4. If necessary, edit the name for the .gpx file.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
