Data Fields
NOTE: Not all data fields are available for all activity types. Some data fields require ANT‍+® or Bluetooth® accessories to display data. Some data fields appear in more than one category on the watch.
TIP: You can also customize the data fields from the watch settings in the Garmin Connect™ app.
Cadence Fields
Name
Description
Average Cadence
Cycling. The average cadence for the current activity.
Average Cadence
Running. The average cadence for the current activity.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cadence
Running. The steps per minute (right and left).
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Cadence
Running. The average cadence for the last completed lap.
Charts
Name
Description
Heart Rate Chart
A chart showing your heart rate throughout the activity.
Pace Chart
A chart showing your pace throughout the activity.
Speed Chart
A chart showing your speed throughout the activity.
Distance Fields
Name
Description
Distance
The distance traveled for the current track or activity.
Int. Distance
The distance traveled for the current interval.
Lap Distance
The distance traveled for the current lap.
Last Lap Dist.
The distance traveled for the last completed lap.
Last Move Dist.
The distance traveled for the last completed move.
Move Distance
The distance traveled for the current move.
Graphical
Name
Description
Cadence Gauge
Running. A color gauge showing your current cadence range.
GCT Balance Gauge
A color gauge showing the left/right balance of ground contact time while running.
Ground Contact Time Gauge
A color gauge showing the amount of time in each step that you spend on the ground while running, measured in milliseconds.
Heart Rate Gauge
A color gauge showing your current heart rate zone.
Heart Rate Zones Ratio
A color gauge showing the ratio of time spent in each heart rate zone.
PacePro Gauge
Running. Your current split pace and your target split pace.
Training Effect Gauge
The impact of the current activity on your aerobic and anaerobic fitness levels.
Vertical Oscillation Gauge
A color gauge showing the amount of bounce while you are running.
Vertical Ratio Gauge
A color gauge showing the ratio of vertical oscillation to stride length.
Heart Rate Fields
Name
Description
% Heart Rate Reserve
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
Aerobic Training Effect
The impact of the current activity on your aerobic fitness level.
Anaerobic Training Effect
The impact of the current activity on your anaerobic fitness level.
Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average HR
The average heart rate for the current activity.
Avg. HR %Max.
The average percentage of maximum heart rate for the current activity.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must have wrist-based heart rate or be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Int. Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Avg. %Max.
The average percentage of maximum heart rate for the current swim interval.
Int. Avg. HR
The average heart rate for the current swim interval.
Int. Max. %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Max. %Max.
The maximum percentage of maximum heart rate for the current swim interval.
Int. Max. HR
The maximum heart rate for the current swim interval.
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Last Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed lap.
Last Lap HR
The average heart rate for the last completed lap.
L. Lap HR %Max.
The average percentage of maximum heart rate for the last completed lap.
Last Move %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed move.
Last Move HR
The average heart rate for the last completed move.
L. Move HR %Max.
The average percentage of maximum heart rate for the last completed move.
Move %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current move.
Move HR
The average heart rate for the current move.
Move HR %Max.
The average percentage of maximum heart rate for the current move.
Time in Zone
The time elapsed in each heart rate zone.
Lengths Fields
Name
Description
Interval Lengths
The number of pool lengths completed during the current interval.
Lengths
The number of pool lengths completed during the current activity.
Other Fields
Name
Description
Active Calories
The calories burned during the activity.
Battery Hours
The number of hours remaining before the battery power is depleted.
Battery Level
The remaining battery power.
eBike Battery
The remaining battery power of an ebike.
eBike Range
The estimated remaining distance the ebike can provide assistance.
GPS
The strength of the GPS satellite signal.
Intervals
The number of intervals completed for the current activity.
Laps
The number of laps completed for the current activity.
Last Round Reps
The number of repetitions in the last round of the activity.
Load
The training load for the current activity. Training load is the amount of excess post-exercise oxygen consumption (EPOC), which indicates the strenuousness of your workout.
Moves
The total number of moves completed during the current activity.
Reps
During a gym activity, the number of repetitions in a workout set.
Respiration Rate
Your respiration rate in breaths per minute (brpm).
Rounds
The number of exercise groups performed in an activity, such as jump rope.
Steps
The number of steps taken during the current activity.
Stress
Your current stress level.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Total Calories
The amount of total calories burned for the day.
Pace Fields
Name
Description
500m Pace
The current rowing pace per 500 meters.
Average 500m Pace
The average rowing pace per 500 meters for the current activity.
Average Pace
The average pace for the current activity.
Int. Pace
The average pace for the current interval.
Lap 500m Pace
The average rowing pace per 500 meters for the current lap.
Lap Pace
The average pace for the current lap.
Last Lap 500m Pace
The average rowing pace per 500 meters for the last lap.
Last Lap Pace
The average pace for the last completed lap.
Last Len. Pace
The average pace for your last completed pool length.
Last Move Pace
The average pace for the last completed move.
Move Pace
The average pace for the current move.
Pace
The current pace.
Rolling Pace
The continuous average pace of the last completed mile or kilometer.
PacePro Fields
Name
Description
Next Split Distance
Running. The total distance of the next split.
Next Split Target Pace
Running. The target pace for the next split.
Split Distance
Running. The total distance of the current split.
Split Distance Remaining
Running. The remaining distance of the current split.
Split Pace
Running. The pace for the current split.
Split Target Pace
Running. The target pace for the current split.
Rest Fields
Name
Description
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Rest Timer
The timer for the current rest (pool swimming).
Run Dynamics
Name
Description
Average GCT Balance
The average ground contact time balance for the current session.
Average Ground Contact Time
The average amount of ground contact time for the current activity.
Average Stride Length
The average stride length for the current session.
Average Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Average Vertical Ratio
The average ratio of vertical oscillation to stride length for the current session.
GCT Balance
The left/right balance of ground contact time while running.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Lap GCT Balance
The average ground contact time balance for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap Stride Length
The average stride length for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Lap Vertical Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Speed Fields
Name
Description
Avg. Moving Speed
The average speed when moving for the current activity.
Avg. Overall Speed
The average speed for the current activity, including both moving and stopped speeds.
Avg. Speed
The average speed for the current activity.
Lap Speed
The average speed for the current lap.
Last Lap Speed
The average speed for the last completed lap.
Last Move Speed
The average speed for the last completed move.
Maximum Speed
The top speed for the current activity.
Move Speed
The average speed for the current move.
Speed
The current rate of travel.
Vertical Speed
The rate of ascent or descent over time.
Stroke Fields
Name
Description
Average Distance Per Stroke
Paddle sports. The average distance traveled per stroke during the current activity.
Indoor skiing. The average distance traveled per stroke during the current activity.
Average Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current activity.
Average Stroke Rate
Indoor skiing. The average number of strokes per minute (spm) during the current activity.
Average Strokes Per Length
The average number of strokes per pool length during the current activity.
Distance Per Stroke
Paddle sports. The distance traveled per stroke.
Distance Per Stroke
Indoor skiing. The distance traveled per stroke.
Interval Strokes Per Length
The average number of strokes per pool length during the current interval.
Interval Stroke Type
The current stroke type for the interval.
Lap Distance Per Stroke
Paddle sports. The average distance traveled per stroke during the current lap.
Indoor skiing. The average distance traveled per stroke during the current lap.
Lap Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current lap.
Lap Stroke Rate
Indoor skiing. The average number of strokes per minute (spm) during the current lap.
Lap Strokes
Paddle sports. The total number of strokes for the current lap.
Lap Strokes
Indoor skiing. The total number of strokes for the current lap.
Last Lap Distance Per Stroke
Paddle sports. The average distance traveled per stroke during the last completed lap.
Indoor skiing. The average distance traveled per stroke during the last completed lap.
Last Lap Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the last completed lap.
Indoor skiing. The average number of strokes per minute (spm) during the last completed lap.
Last Lap Strokes
Paddle sports. The total number of strokes for the last completed lap.
Last Lap Strokes
Indoor skiing. The total number of strokes for the last completed lap.
Last Length Strokes
The total number of strokes for the last completed pool length.
Last Length Stroke Type
The stroke type used during the last completed pool length.
Stroke Rate
Paddle sports. The number of strokes per minute (spm).
Stroke Rate
Indoor skiing. The number of strokes per minute (spm).
Strokes
Paddle sports. The total number of strokes for the current activity.
Strokes
Indoor skiing. The total number of strokes for the current activity.
Swolf Fields
Name
Description
Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology).
Interval Swolf
The average swolf score for the current interval.
Last Length Swolf
The swolf score for the last completed pool length.
Temperature Fields
Name
Description
24-Hour Maximum
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
24-Hour Minimum
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor. You can pair a tempe™ sensor with your device to provide a consistent source of accurate temperature data.
Timer Fields
Name
Description
Active Time
The total time of active movement for the current activity.
Average Lap Time
The average lap time for the current activity.
Average Move Time
The average move time for the current activity.
Average Pose Time
The average pose time for the current activity.
Elapsed Time
The total time recorded. For example, if you start the activity timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Estimated Finish Time
The estimated finish time of the current activity.
Interval Time
The stopwatch time for the current interval.
Lap Time
The stopwatch time for the current lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Move Time
The stopwatch time for the last completed move.
Last Pose Time
The stopwatch time for the last completed pose.
Move Time
The stopwatch time for the current move.
Moving Time
The total time moving for the current activity.
Overall Ahead/Behind
The overall time ahead or behind of the target pace or speed.
Pose Time
The stopwatch time for the current pose.
Set Timer
During a strength training activity, the amount of time spent in the current workout set.
Stopped Time
The total time stopped for the current activity.
Swim Time
The swimming time for the current activity, not including rest time.
Timer
The current time of the activity timer.
Workout Fields
Name
Description
Reps to Go
During a workout, the remaining repetitions.
Step Duration
The time or distance remaining for the workout step.
Step Pace
The current pace during the workout step.
Step Speed
The current speed during the workout step.
Step Time
The time elapsed for the workout step.
GUID-E3AB50C9-691D-4482-8387-7EEB3961CA87 v3
November 2026
