Data Fields
The tables contain data fields for the Edge® 1050 cycling computer. If you have another compatible device, see your device owner's manual.
NOTE: Data fields that display pedal smoothness, torque effectiveness, and balance data are not supported by the Rally™ 110 system.
Power Fields
Name
Description
%FTP
The current power output as a percentage of functional threshold power.
3s Balance
The 3-second moving average of the left/right power balance.
3s Force
The 3-second moving average of force applied to the pedal platforms, in Newtons.
3s Power
The 3-second moving average of power output.
3s Watts/kg
The 3-second moving average of power output in watts per kilogram.
10s Balance
The 10-second moving average of the left/right power balance.
10s Force
The 10-second moving average of force applied to the pedal platforms, in Newtons.
10s Power
The 10-second moving average of power output.
10s Watts/kg
The 10-second moving average of power output in watts per kilogram.
30s Balance
The 30-second moving average of the left/right power balance.
30s Force
The 30-second moving average of force applied to the pedal platforms, in Newtons.
30s Power
The 30-second moving average of power output.
30s Watts/kg
The 30-second moving average of power output in watts per kilogram.
Avg Balance
The average left/right power balance for the current activity.
Avg Force
The average force applied to the pedal platforms during the activity, in Newtons.
Avg Power
The average power output for the current activity.
Avg Watts/kg
The average power output in watts per kilogram.
Balance
The current left/right power balance.
Force
The force applied to the pedal platforms, in Newtons.
Intensity Factor
The Intensity Factor™ for the current activity.
Kilojoules
The accumulated work performed (power output) in kilojoules.
Lap Balance
The average left/right power balance for the current lap.
Lap Force
The average force applied to the pedal platforms during the current lap, in Newtons.
Lap Norm. Force
The normalized force applied to the pedal platforms during the current lap, in Newtons.
Lap NP
The average Normalized Power™ for the current lap.
Lap Power
The average power output for the current lap.
Lap Watts/kg
The average power output in watts per kilogram for the current lap.
Last Lap Force
The average force applied to the pedal platforms during the previous lap, in Newtons.
Last Lap Norm. Force
The normalized force applied to the pedal platforms during the previous lap, in Newtons.
Last Lap NP
The average Normalized Power for the last completed lap.
Last Lap Power
The average power output for the last completed lap.
Max. Force
The maximum force applied to the pedal platforms during the activity, in Newtons.
Max. Lap Force
The maximum force applied to the pedal platforms during the current lap, in Newtons.
Max. Lap Power
The top power output for the current lap.
Max. Power
The top power output for the current activity.
Normalized Force
The normalized force applied to the pedal platforms, in Newtons.
Normalized Power
The Normalized Power for the current activity.
Pedal Smoothness
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
Power
The current cycling power output in watts.
Power Zone
The current range of power output (1 to 9) based on your FTP or custom settings.
Time in Zone
The time elapsed in each power zone.
Torque Effectiveness
The measurement of power lost to negative force applied to the pedals during the back stroke.2
TSS
The Training Stress Score™ for the current activity.
Watts/kg
The amount of power output in watts per kilogram.
Cycling Dynamics Fields
NOTE: These data fields require a Rally 210 system.
Name
Description
Avg L. Peak Pwr Phase
The average power phase peak angle for the left leg for the current activity.
Avg Left Pwr Phase
The average power phase angle for the left leg for the current activity.
Avg PCO
The average platform center offset for the current activity.
Avg Right Pwr Phase
The average power phase angle for the right leg for the current activity.
Avg R. Peak Pwr Phase
The average power phase peak angle for the right leg for the current activity.
Lap L. Peak Pwr Phase
The average power phase peak angle for the left leg for the current lap.
Lap Left Pwr Phase
The average power phase angle for the left leg for the current lap.
Lap PCO
The average platform center offset for the current lap.
Lap R. Peak Pwr Phase
The average power phase peak angle for the right leg for the current lap.
Lap Right Pwr Phase
The average power phase angle for the right leg for the current lap.
Lap Time Seated
The time spent seated while pedaling for the current lap.
Lap Time Standing
The time spent standing while pedaling for the current lap.
Left Peak Pwr Phase
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Left Power Phase
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
Platform Center Offset
The location on the pedal platform where force is applied, relative to the center line of the pedal platforms.
Right Peak Pwr Phase
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Right Power Phase
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
Time Seated
The time spent seated while pedaling for the current activity.
Time Standing
The time spent standing while pedaling for the current activity.
1 Torque Effectiveness and Pedal Smoothness are supported on Rally 210 models only. If your watch or cycling computer is connected to your pedals using an ANT‍+® connection, you must turn on Torque Effectiveness and Pedal Smoothness in the sensor settings to enable the corresponding data fields. Torque Effectiveness and Pedal Smoothness are not supported when using an open Bluetooth® connection. For more information on connection types, go to garmin.com/connectiontypes.
2 Torque Effectiveness and Pedal Smoothness are supported on Rally 210 models only. If your watch or cycling computer is connected to your pedals using an ANT‍+ connection, you must turn on Torque Effectiveness and Pedal Smoothness in the sensor settings to enable the corresponding data fields. Torque Effectiveness and Pedal Smoothness are not supported when using an open Bluetooth connection. For more information on connection types, go to garmin.com/connectiontypes.
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
