Changing Pedal Bodies
WARNING
You must tighten the spindle nut and cover according to the specified torque requirements. Too much or not enough torque may lead to product damage or serious personal injury or death.
NOTICE
Garmin® recommends changing one pedal at a time, taking care to keep track of the parts for each pedal. The spindle nut and the outer cap of the right pedal have left-handed (reverse) threads.
NOTICE
You must apply grease to the spindles and pedal bodies as specified in these instructions. Changing the pedal bodies without appropriate grease application causes product damage.
The Rally™ RK/XC 210 and Rally RS/XC 210 bundles include a pair of road bike pedal bodies and a pair of mountain bike pedal bodies. You can purchase additional pedal bodies for the Rally 110/210 spindles from your Garmin dealer, or you can go to garmin.com.
These instructions show the Rally RK pedal body. The steps are the same for any pedal body type.
  1. Use a 15 mm wrench to remove the pedal from your bike.
  2. Using the wrench to hold the spindle steady, use a 5 mm hex key to remove the cover.
    Removing the outer door.
    NOTICE
    The cover on the right pedal has a left-handed (reverse) thread. Turning the cover in the wrong direction may break the cover and damage the spindle.
    Thread direction on the cover
  3. Using the wrench to hold the spindle steady, use a 5 mm hex key to remove the spindle nut.
    NOTE: The spindle nut on the right pedal has a left-handed (reverse) thread.
  4. Remove the pedal body from the spindle.
    Removing the spindle.
  5. Wipe all grease off the spindle, and apply a thin layer of new grease to the highlighted areas.
    NOTE: You should apply enough grease to fill the groove on the rubber seal 1.
    Spindle with a callout
  6. Apply a thin layer of grease to the roller bearing inside the new pedal body.
    Greasing the roller bearing in the pedal body
  7. Insert the spindle into the new pedal body, and rotate it a few times to distribute the grease.
  8. Use a 5 mm hex key to install the spindle nut, and tighten it to 10 N-m (88 lbf-in.).
  9. Apply a thin layer of grease to the O-ring around the cover.
    Greasing the outboard door seal.
  10. Use a 5 mm hex key to install the cover and tighten it to 5 N-m (44 lbf-in.).
  11. Wipe off all excess grease.
  12. Repeat steps 1 through 11 for the other pedal.
NOTICE
You should wipe off all grease inside the pedal bodies before storing them. Storing the pedals with old grease or debris inside them may lead to product damage.
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
