Upgrading a Rally 110 System
You can upgrade a single-sensing Rally™ 110 pedal power meter to a dual-sensing Rally 210 system by adding a Rally 110 upgrade spindle, to access advanced training data (Cycling Dynamics).
You can purchase a Rally 110 upgrade spindle from your Garmin® dealer, or you can go to garmin.com.
Turning On the New Spindle
The new spindle is packaged in travel mode to preserve battery life. You must briefly connect it to a power source to turn it on.
Installing the New Spindle
You must tighten the spindle nut and cover according to the specified torque requirements. Too much or not enough torque may lead to product damage or serious personal injury or death.
You must apply grease to the new spindle according to the instructions below. Installing the new spindle without appropriate grease application causes product damage.
Pairing the New Spindle
You can pair the new spindle with your Rally 110 spindle using the Garmin Connect™ app or using a compatible Edge® bike computer.
Pairing the New Spindle Using the Garmin Connect App
- Rotate the cranks to wake up the pedals.
- On the Garmin Connect app, select .
- Enter the 7-digit pairing code found on the new spindle.
The status LED flashes (green) on both spindles.
Pairing the New Spindle Using an Edge Bike Computer
- Rotate the crank arm until the status LED flashes on both pedals.
- From the Settings menu, select Sensors.
- Select the Rally 110 power meter.
- Select .
The status LED flashes (green) on both pedals.
