Pairing the Rally 110/210 Pedals
You must pair the pedals with the Garmin Connect™ app to get the latest software updates and to pair the pedals securely with other devices.
Getting Started with the Garmin Connect App
For more information about the Garmin Connect app, go to garmin.com/garminconnect_help.
Pairing with the Garmin Connect App
Pairing the Rally 110/210 Pedals Securely Without the Garmin Connect App
If you have already paired the Rally 110/210 pedals with the Garmin Connect app but you have lost access to your mobile device or are unable to use the Garmin Connect app on it, you can follow the steps to enable secure pairing mode.
Pairing with a Watch or Cycling Computer
Before you can pair the Rally 110/210 pedals with a watch or a cycling computer, you must pair the pedals with the Garmin Connect app (Pairing with the Garmin Connect App).
You can follow these steps to pair your Rally 110/210 pedals with a device that supports secure pairing. To access an up-to-date list of Garmin devices that support secure connections, and learn more about open and secure connections, go to garmin.com/connectiontypes.
To pair with a device that does not support secure pairing, you must first set your pedals to allow open connections (Allowing Open Connections).
After you have paired the pedals with a compatible watch or cycling computer, you should set the correct crank length, to ensure accurate power measurements (Entering the Crank Length).
The Rally 110/210 pedals support secure Bluetooth® connections with compatible devices. To pair the Rally 110/210 pedals with older devices that do not support secure pairing, you must configure the pedals to allow open connections.
The status LED on the Rally 110/210 pedal flashes three times when it is idle and allowing open connections.
You can pair your device by adding the Rally 110/210 pedals as a new sensor.
You must enter the correct crank length to ensure accurate power calculations. If you do not enter a crank length, the Rally 110/210 pedals use a default crank length of 172.5 mm (6.79 in.).
