Service Kits
You can order the most common replacement parts and accessories at garmin.com/accessories/gmr_xhd3_open_array_radar.
To order the service kits listed in this manual, you can contact Garmin® Support at support.garmin.com.
If you are a Garmin dealer, you should contact your Garmin representative to order service kits.
Service Kit Number |
Description |
S00-02172-00 (GMR™ 434/436 xHD3) S00-02173-00 (GMR 1234/1236 xHD3) S00-02174-00 (GMR 2534/2536 xHD3) |
Electronics box and magnetron |
S00-00600-04 |
Pedestal housing cover1
S00-00600-05 |
Pedestal grounding hardware |
S00-00600-07 |
Antenna rotary joint |
S11-06002-00 (GMR 434/436 xHD3) S11-06002-04 (all other GMR xHD3 open array models) |
Pedestal housing2
S00-00600-10 (GMR 434/436 xHD3) S00-02542-00 (all other GMR xHD3 open array models) |
Internal power cable |
S00-00600-11 |
Hall effect magnet |
S00-00600-13 (GMR 434/436 xHD3) S00-00600-14 (all other GMR xHD3 open array models) |
Circulator/waveguide assembly |
S00-02050-00 |
LNC3
S00-00490-00 |
Status LED cable |
S00-00382-00 |
Access panel |
S00-02053-00 |
Internal network cable |
S00-02051-00 |
Motor/gearbox assembly4
S00-02052-00 |
Pedestal cables5
S11-01315-50 |
Voltage converter |
320-01052-00 |
15 m (49.21 ft.) Garmin BlueNet™ Cable |
S00-01312-00 |
Protective cap for the antenna rotary joint waveguide6
S00-00740-00 |
71 mm M10 threaded rod |
K00-01414-00 |
Installation hardware and manuals7
S11-03579-50 |
Antenna position sensor board |
T10-00114-00 |
Radar service kit8
Includes screws and washers.
Includes pedestal housing cover, access panel, internal power cable, internal network cable and status LED cable.
Includes four 70 mm M4 screws and one 10 mm M4 screw, for mounting. Does not include LNC coaxial cable and data cable. See Pedestal Cables kit (S00-02052-00).
Includes the motor control board power cable and four mounting screws.
Includes the antenna position sensor cable, the LNC coaxial cable, the LNC data cable, and the motor control board cable.
Plastic cover to protect the exposed end of the antenna rotary joint during transport.
Includes four 71 mm M10 threaded rods, with washers and nuts, and mounting template.
Includes the antenna terminator.
