Enabling Auto Climb
You can use the auto climb feature to detect elevation changes automatically. You can use it during activities such as climbing, hiking, running, or biking.
  1. Hold MENU.
  2. Select Settings > Activities & Apps.
  3. Select an activity.
    NOTE: This feature is not available for all activities.
  4. Select the activity settings.
  5. Select Auto Climb > Status > On.
  6. Select an option:
    • Select Run Screen to identify which data screen appears while running.
    • Select Climb Screen to identify which data screen appears while climbing.
    • Select Invert Colors to reverse the display colors when changing modes.
    • Select Vertical Speed to set the rate of ascent over time.
    • Select Mode Switch to set how quickly the device changes modes.
Copyright © Garmin. All rights reserved.GUID-DB0B2E91-DAF6-46B9-B1D2-89EDA37A56DC v2
