Calculating the Size of an Area
Before you can calculate the size of an area, you must acquire satellites.
  1. From the watch face, press GPS.
  2. Select Area Calc..
  3. Walk around the perimeter of the area.
    TIP: You can hold MENU, and select Pan/Zoom to adjust the map (Panning and Zooming the Map).
  4. Press GPS to calculate the area.
  5. Select an option:
    • To exit without saving, select Done.
    • To convert measurements of the area to a different unit of measure, select Change Units.
    • To save, select Save Activity.
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
