Changing the Backlight Settings
  1. From the watch face, hold MENU.
  2. Select Settings > System > Backlight.
  3. Select Night Vision to reduce the backlight intensity for compatibility with night vision goggles (optional).
  4. Select an option:
    • Select During Activity.
    • Select Not During Activity.
  5. Select an option:
    • Select Keys to turn on the backlight for key presses.
    • Select Alerts to turn on the backlight for alerts.
    • Select Gesture to turn on the backlight by raising and turning your arm to look at your wrist.
    • Select Timeout to set the length of time before the backlight turns off.
    • Select Brightness to set the brightness level of the backlight.
      NOTE: If you enable night vision mode, you cannot adjust the brightness level.
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
