Adding or Removing a Favorite Activity
The list of your favorite activities appears when you press GPS from the watch face, and it provides quick access to the activities you use most frequently. The first time you press GPS to start an activity, the device prompts you to select your favorite activities. You can add or remove favorite activities at any time.
  1. Hold MENU.
  2. Select Settings > Activities & Apps.
    Your favorite activities appear at the top of the list with a white background. Other activities appear in the extended list with a black background.
  3. Select an option:
    • To add a favorite activity, select the activity, and select Set as Favorite.
    • To remove a favorite activity, select the activity, and select Remove from Favorites.
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
