Stopping an Activity
  1. Press GPS.
  2. Select an option:
    • To resume your activity, select Resume.
    • To save the activity and return to watch mode, select Save > Done.
    • To suspend your activity and resume it at a later time, select Resume Later.
    • To mark a lap, select Lap.
    • To navigate back to the starting point of your activity along the path you traveled, select Back to Start > TracBack.
      NOTE: This feature is available only for activities that use GPS.
    • To navigate back to the starting point of your activity by the most direct path, select Back to Start > Straight Line.
    • To measure the difference between your heart rate at the end of the activity and your heart rate two minutes later, select Recovery HR, and wait while the timer counts down.
    • To discard the activity and return to watch mode, select Discard > Yes.
    NOTE: After stopping the activity, the device saves it automatically after 30 minutes.
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
