Starting an Activity When you start an activity, GPS turns on automatically (if required). From the watch face, press GPS. Select an option: Select an activity from your favorites. Select , and select an activity from the extended activity list. If the activity requires GPS signals, go outside to an area with a clear view of the sky, and wait until the device is ready. The device is ready after it establishes your heart rate, acquires GPS signals (if required), and connects to your wireless sensors (if required). Press GPS to start the activity timer. The device records activity data only while the activity timer is running. Child Topics:Tips for Recording ActivitiesPower ModesParent Topic: Activities and Apps
Starting an Activity When you start an activity, GPS turns on automatically (if required). From the watch face, press GPS. Select an option: Select an activity from your favorites. Select , and select an activity from the extended activity list. If the activity requires GPS signals, go outside to an area with a clear view of the sky, and wait until the device is ready. The device is ready after it establishes your heart rate, acquires GPS signals (if required), and connects to your wireless sensors (if required). Press GPS to start the activity timer. The device records activity data only while the activity timer is running. Child Topics:Tips for Recording ActivitiesPower ModesParent Topic: Activities and AppsHomeActivities and AppsStarting an Activity
