Setting an Alarm
You can set multiple alarms. You can set each alarm to sound once or to repeat regularly.
  1. From any screen, hold SET.
  2. Select Alarms.
  3. Enter the alarm time.
  4. Select Repeat, and select when the alarm should repeat (optional).
  5. Select Sounds, and select a type of notification (optional).
  6. Select Backlight > On to turn on the backlight with the alarm (optional).
  7. Select Label, and select a description for the alarm (optional).
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
