Recording a Strength Training Activity
You can record sets during a strength training activity. A set is multiple repetitions (reps) of a single move.
  1. From the watch face, press GPS.
  2. Select Strength.
    The first time you record a strength training activity, you must select which wrist your watch is on.
  3. Press GPS to start the set timer.
  4. Start your first set.
    The device counts your reps. Your rep count appears when you complete at least four reps.
    TIP: The device can only count reps of a single move for each set. When you want to change moves, you should finish the set and start a new one.
  5. Press BACK to finish the set.
    The watch displays the total reps for the set. After several seconds, the rest timer appears.
  6. If necessary, press DOWN, and edit the number of reps.
    TIP: You can also add the weight used for the set.
  7. When you are done resting, press BACK to start your next set.
  8. Repeat for each strength training set until your activity is complete.
  9. After your last set, press GPS to stop the set timer.
  10. Select Save.
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
