Changing the GPS Setting For more information about GPS, go to www.garmin.com/aboutGPS. Hold MENU. Select Settings > Activities & Apps. Select the activity to customize. Select the activity settings. Select GPS. Select an option: Select Off to disable GPS for the activity. Select Normal (GPS Only) to enable the GPS satellite system. Select GPS + GLONASS (Russian satellite system) for more accurate position information in situations with poor sky visibility. Select GPS + GALILEO (European Union satellite system) for more accurate position information in situations with poor sky visibility. Select UltraTrac to record track points and sensor data less frequently (UltraTrac). NOTE: Using GPS and another satellite together can reduce battery life more quickly than using GPS only (GPS and Other Satellite Systems). Child Topics:GPS and Other Satellite SystemsUltraTracParent Topic: Activities and App Settings
Changing the GPS Setting For more information about GPS, go to www.garmin.com/aboutGPS. Hold MENU. Select Settings > Activities & Apps. Select the activity to customize. Select the activity settings. Select GPS. Select an option: Select Off to disable GPS for the activity. Select Normal (GPS Only) to enable the GPS satellite system. Select GPS + GLONASS (Russian satellite system) for more accurate position information in situations with poor sky visibility. Select GPS + GALILEO (European Union satellite system) for more accurate position information in situations with poor sky visibility. Select UltraTrac to record track points and sensor data less frequently (UltraTrac). NOTE: Using GPS and another satellite together can reduce battery life more quickly than using GPS only (GPS and Other Satellite Systems). Child Topics:GPS and Other Satellite SystemsUltraTracParent Topic: Activities and App SettingsHomeCustomizing Your DeviceActivities and App SettingsChanging the GPS Setting
