Pairing Your Wireless Sensors
The first time you connect a wireless sensor to your device using ANT‍+® or Bluetooth® technology, you must pair the device and sensor. After they are paired, the device connects to the sensor automatically when you start an activity and the sensor is active and within range.
  1. If you are pairing a heart rate monitor, put on the heart rate monitor.
    The heart rate monitor does not send or receive data until you put it on.
  2. Bring the device within 3 m (10 ft.) of the sensor.
    NOTE: Stay 10 m (33 ft.) away from other wireless sensors while pairing.
  3. Hold MENU.
  4. Select Settings > Sensors & Accessories > Add New.
  5. Select an option:
    • Select Search All.
    • Select your sensor type.
    After the sensor is paired with your device, the sensor status changes from Searching to Connected. Sensor data appears in the data screen loop or a custom data field.
Copyright © Garmin. All rights reserved.GUID-DA71CC59-DC5F-4E35-BBC3-33D588DADC81 v4
