Using Cycling Dynamics
Before you can use cycling dynamics, you must pair the power meter with your device using ANT‍+® technology (Pairing Your Wireless Sensors).
NOTE: Recording cycling dynamics uses additional device memory.
  1. Go for a ride.
  2. Scroll to the cycling dynamics screen to view your power phase data Callout number one, total power Callout number two, and platform center offset Callout number three.
    Cycling dynamics data with callouts
  3. If necessary, hold a data field Callout number four to change it (Adding a Data Screen).
    NOTE: The two data fields at the bottom of the screen can be customized.
You can send the ride to the Garmin Connect™ app to view additional cycling dynamics data (Sending Your Ride to Garmin Connect).
Copyright © Garmin. All rights reserved.GUID-D9E9CF32-5A89-4140-8B6A-0A61633E397F v4
