In-Hull Transducers Overview
These transducers attach to the inside floor of the hull.
The following list describes in-hull transducers.
In-hull transducer
  • Do not require a hole through the hull
  • Send the signal from within the vessel which reduces signal strength
  • Perform well at high speeds, if installed away from turbulence
  • Less likely to sustain external damage (ideal for trailered boats)
  • May require a professional installer for best results
  • May require maintenance to refill the tank or chamber
  • Can be installed while the vessel is in the water
  • Recommended for solid fiberglass hulls only, up to 16 mm (5/8 in.) thickness
  • Recommended for hulls with a deadrise angle of 0 to 25 degrees (models vary) (Deadrise Angle)
  • Not recommended for metal, wood, or cored-hull boats
  • Do not create drag or turbulence
  • Typically do not include a temperature or speed sensor
GUID-D86E00AF-F9B3-497A-9F52-6EE1C2E12A51 v2
September 2026
