Viewing a Live Weather Map
While your dive computer is connected to a phone or Wi‑Fi® network with internet access, you can view a live weather map showing weather radar, precipitation, cloud cover, temperature, or wind conditions.
  1. From the home screen, scroll down to the extended app list.
  2. Select Weather & Tides.
  3. Tap the map.
  4. Select Menu.
  5. Select an option:
    NOTE: Some options may not be available in all areas.
    • To view a weather radar projection, select Play.
    • To view precipitation, select Change Overlay > Precipitation.
    • To view cloud coverage, select Change Overlay > Cloud Coverage.
    • To view temperatures, select Change Overlay > Temperature.
    • To view wind speeds and directions, select Change Overlay > Wind.
    The selected data appears on the map. The dive computer may take a few moments to load the weather map data.
  6. Select an option to pan and zoom the map:
    • To use the touchscreen, tap and drag the map, and select Zoom in or Zoom out to zoom in or out.
    • To use the buttons, select Menu > Pan/Zoom, and press PREV or NEXT to zoom in or out.
      NOTE: You can press ENTER to toggle between panning up and down, panning left and right, or zooming.
GUID-D6BA1847-E20D-4241-B08C-DF0D8B052B28 v6
September 2026
