Saving or Navigating to a Location on the Map
You can select any location on the map. You can save the location or start navigating to it.
  1. From the home screen, scroll down to the extended app list, and select Map.
  2. Select an option:
    • To use the touchscreen, tap the map, tap and drag to position the crosshairs, and press PREV or NEXT to zoom in or out.
    • To use the buttons, press ENTER, select Pan/Zoom, and press PREV or NEXT to zoom in or out.
      NOTE: You can press ENTER to toggle between panning up and down, panning left and right, or zooming.
    Location information appears at the top of the map.
  3. Hold ENTER.
  4. Press ENTER.
  5. Select an option:
    • To save the location, select Save Location.
    • To start navigating to the location, select Navigate To.
    • To return to the map view, select View on Map.
GUID-D6BA1847-E20D-4241-B08C-DF0D8B052B28 v6
September 2026
