Wiring to Power
- Route the power cable from the mount to the boat battery or fuse block.
- If necessary, extend the wires using 0.82 mm2 (18 AWG) or larger wire.
- Connect the red wire to the positive terminal on the battery or fuse block, and connect the black wire to the negative terminal.
Parent Topic: Installing the Cables and Connectors
