Specifications
All Models
Material |
Polycarbonate plastic |
Water rating |
IEC 60529 IPX71 |
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Input voltage |
From 9 to 18 Vdc |
Fuse |
3 A, 125 V fast-acting |
Compass-safe distance |
65 cm (25.6 in.) |
NMEA 2000® LEN @ 9 Vdc2 |
1 |
NMEA 2000 draw3 |
75 mA max. |
Memory card |
1 microSD® card slot; 32 GB max. card size |
6-Inch Models
Dimensions (W x H x D) |
21.8 x 13.0 x 6.2 cm (8.6 x 5.1 x 2.6 in.) |
Display size (W x H) |
13.7 x 7.7 cm (5.4 x 3.1 in.) 15.2 cm (6.2 in.) diagonal |
Clearance to nearest obstruction |
8 cm (3.1 in.) |
Weight |
0.75 kg (1.6 lb.) |
Max. power draw at 10 Vdc |
12 W |
Typical current draw at 12 Vdc (RMS) |
0.7 A |
Max. current draw at 12 Vdc (RMS) |
1.25 A |
Wireless frequencies and protocols |
2.4 GHz @ 17.2 dBm nominal |
7-Inch Models
25 x 13.9 x 5.1 cm ( 9.8 x 5.5 x 2.0 in.) |
15.5 x 8.6 cm (6.1 x 3.4 in.) 17.8 cm (7 in.) diagonal |
11.5 cm (4.5 in.) |
Weight |
0.77 kg (1.7 lb.) |
15 W, 9 W with a GT-52 transducer |
0.8 A |
Max. current draw at 12 Vdc (RMS)1 |
1.25 A |
2.4 GHz @ 18.5 dBm nominal |
9-Inch Models
11.4" x 6.5" x 2.4" (28.2 x 16.4 x 6.0 cm) |
19.9 x 11.3 cm (7.8 x 4.8 in.) 22.9 cm (9 in.) diagonal |
11.5 cm (4.5 in.) |
Weight |
1 kg (2.3 lb.) |
18 W |
1 A |
1.5 A |
