Installing the Device in the Cradle
After the cables are connected to the cradle, you can quickly place the device in the cradle.
  1. Place the base of the device in the bottom of the cradle.
  2. Tilt the top of the device toward the cradle until it fastens in place.
There is an audible click when the device is secured in the cradle.
NOTICE
You should make sure the device is firmly secured in the cradle. If the model uses a locking bracket, make sure the bracket is firmly snapped shut. There is an audible click when the device or locking bracket is installed correctly. If the device is not firmly secured, it can lose power. The device can also fall out of the cradle and become damaged if it is not firmly secured.
Copyright © Garmin. All rights reserved.GUID-D4F04D40-7D5A-4040-AD3F-27506E0DAFD0 v3
