Using the Saved App
You can use the saved app to view your saved locations, activity locations, and courses.
  1. From the watch face, press GPS.
  2. Select Saved.
  3. Select a saved item.
  4. Select an option:
    • To navigate to the location, select Go To.
    • To navigate the course, select Do Course.
    • To navigate the course in reverse, select Do Course in Reverse.
    • To navigate to the start of the activity, select Back to Start.
    • To view location details, select Details.
    • To edit the name of the location or course, select Name.
    • To edit the location icon, select Icon.
    • To edit the coordinates of the location, select Position.
    • To edit the elevation of the location, select Elevation.
    • To view a graph of the elevation level, select Elevation Plot.
    • To edit the course, select Edit.
    • To show the course or activity location on the map, even when you are not navigating, select Map.
    • To delete the location or course, select Delete.
GUID-D3C2D1F9-D2C0-404D-9372-7B2D57459BF8 v4
May 2026
