Managing Maps
Before you can manage your map data, you must connect to a Wi‑Fi® network (Setting Up Wi‑Fi Connectivity).
You can view, update, and delete the downloaded maps on your Edge® bike computer.
  1. Select Menu symbol > Settings > System > Map Manager.
  2. Select an option:
    • To update a map, select Cycling Maps or Other Maps, select a map, and select Download Update.
      TIP: When an update is available, the notification appears under the map name.
    • To download a new map, select Plus symbol, select a map, and select Download Update. When the download is complete, select Install Update > Checkmark symbol
    • To delete a map, select Cycling Maps or Other Maps, select a map, and select Menu symbol > Remove > Checkmark symbol.
      NOTE: Some preloaded maps cannot be deleted.
GUID-D3621248-CC5B-4F04-B004-6F6FD9FDFEB0 v1
October 2026
