Navigating to Your Starting Point During an Activity
You can navigate back to the starting point of your current activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
  1. During an activity, press STOP.
  2. Select Back to Start, and select an option:
    • To navigate back to the starting point of your activity along the path you traveled, select TracBack.
    • If you do not have a supported map or are using direct routing, select Route to navigate back to the starting point of your activity in a straight line.
    • If you are not using direct routing, select Route to navigate back to the starting point of your activity using turn-by-turn directions.
    Screenshot of the track to follow with callouts
    Your current location 1, the track to follow 2, and your destination 3 appear on the map.
GUID-D21041B7-7A8E-4D01-9DC0-093D2DC7049A v6
August 2025
