Showing and Hiding Map Data
You can choose the map data to show on the map and save map data themes for multiple activities.
  1. From the watch face, press START.
  2. Select Map.
  3. Press START.
  4. Select Map Layers.
  5. Select an option:
    • To customize the map data for an activity type, select Activity Theme, and select an activity.
      Changes you make to the map data settings are saved to the selected activity theme.
    • To turn on specific map features, such as contour lines or saved locations, select the map feature, and select Status > On.
      TIP: You can select Apply to all Activities to apply the setting to all activity themes.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
