Navigating to a Shared Location During an Activity
This feature is designed for activities using GPS. If GPS is turned off for your activity, you can view the location later.
TIP: The location is saved to your watch. To view the location later, press START, and select Navigate > Saved Locations.
You can receive shared locations on your watch and navigate to those locations (Sharing a Location From a Map Using the Garmin Connect App).
  1. Start a GPS activity (Starting an Activity).
    Your watch displays a notification indicating the name of a shared location.
  2. Select Check mark to navigate to the shared location.
  3. Follow the on-screen instructions to proceed to your destination.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
