Viewing Tide Information
WARNING
Tide information is for information purposes only. It is your responsibility to heed all posted water-related guidance, to remain aware of your surroundings, and to use safe judgment in, on, and around the water at all times. Failure to heed this warning could result in serious personal injury or death.
You can view information about a tide station, including the tide height and when the next high and low tides will occur. You can save up to ten tide stations.
  1. From the watch face, press START.
  2. Select Tides.
  3. Select an option:
    • To use your current location when you are near a tide station, select Add > Current Location.
    • To select a location on the map, select Add > Use Map.
    • To enter the name of a city, select Add > City Search.
    • To select a saved location, select Add > Saved Locations.
    • To enter coordinates for a location, select Add > Coordinates.
    A 24-hour tide chart appears for the current date with the current tide height 1 and information about the next high and low tides 2.
    Tide data with callouts
  4. Press DOWN to see tide information for upcoming days.
  5. Press START, and select Set as Favorite to set this location as your favorite tide station.
    Your favorite tide station appears at the top of the list in the app and in the glance.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
