Cross-Country Skiing Power Data
NOTE: The HRM-Pro™ series accessory must be paired to the MARQ® watch using ANT‍+® technology.
You can use your compatible MARQ watch paired with the HRM-Pro series accessory to provide real-time feedback about your cross-country skiing performance. The power output is measured in watts. Factors that affect power include your speed, elevation changes, wind, and snow conditions. You can use power output to measure and improve your skiing performance.
NOTE: Skiing power values are generally lower than cycling power values. This is normal and occurs because humans are less efficient at skiing than they are at cycling. It is common for ski power values to be 30 to 40 percent lower than cycling power values at the same training intensity.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
