Golf Menu
During a round, you can press START to access additional features in the golf menu.
End Round
Ends the current round.
Change Hole
Allows you to manually change the hole.
Change Green
Allows you to change the green when more than one green is available for a hole.
View Green
Allows you to move the pin location to get a more precise distance measurement (Moving the Flag).
Virtual Caddie
Requests a club recommendation from the virtual caddie (Virtual Caddie).
PlaysLike
Shows the PlaysLike factors for the hole ( PlaysLike Distance Icons).
Measure Shot
Shows the distance of your previous shot recorded with the Garmin AutoShot™ feature (Viewing Measured Shots). You can also manually record a shot (Manually Measuring a Shot).
Scorecard
Opens the scorecard for the round (Keeping Score).
Odometer
Shows the recorded time, distance, and steps traveled. The odometer automatically starts and stops when you start or end a round. You can reset the odometer during a round.
Wind
Opens a pointer that shows the wind direction and speed relative to the pin (Viewing the Wind Speed and Direction).
PinPointer
The PinPointer feature is a compass that points to the pin location when you are unable to see the green. This feature can help you line up a shot even if you are in the woods or in a deep sand trap.
NOTE: Do not use the PinPointer feature while in a golf cart. Interference from the golf cart can affect the accuracy of the compass.
Custom Targets
Allows you to save a location, such as an object or obstacle, for the current hole (Saving Custom Targets).
Club Stats
Shows your statistics with each golf club, such as distance and accuracy information. Appears when you pair Approach® CT10 sensors or enable the Club Prompt setting.
Sunrise & Sunset
Shows the sunrise, sunset, and twilight times for the current day.
Settings
Allows you to customize the golf activity settings (Activities and App Settings).
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
