Adding a Stock
Before you can customize the stocks list, you must add the stocks glance to the glance loop (Customizing the Glance Loop).
  1. From the watch face, press UP or DOWN to view the stocks glance.
  2. Press START.
  3. Select Add Stock.
  4. Enter the company name or stock symbol for the stock you want to add, and select Check mark.
    The watch displays search results.
  5. Select the stock you want to add.
  6. Select the stock to view more information.
    TIP: To display the stock on the glance loop, you can press START, and select Set as Favorite.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
