Setting the Starting Line
  1. From the watch face, press START.
  2. Select Sail Race.
  3. Wait while the device locates satellites.
  4. Hold MENU.
  5. Select Start Line Settings.
  6. Select an option:
    • Select Mark Port to mark the port starting line mark as you sail past it.
    • Select Mark Starboard to mark the starboard starting line mark as you sail past it.
    • Select Time to Burn to enable or disable the time to burn data on the regatta timer data screen.
    • Select Distance to Start to set the distance to the start line, preferred distance units, and length of your boat.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
