Mounting the Gesture Remote to a Fishing Rod Blank
  1. Locate the rod mount, zip ties, and rubber liner.
    The fishing pole rod mount for the gesture remote
  2. Slide a zip tie through each of the two slots on the back of the rod mount.
  3. Set the rubber liner inside the zip ties.
  4. Test the fit of the rubber liner around your rod blank.
  5. If the rubber liner is too long to fit snugly around the rod blank, trim the ends off as needed with a pair of scissors.
  6. Place the mount where you want it on the fishing rod blank.
  7. Slide the end of each zip tie into the head and pull until they are tight.
  8. Press the remote into the mount until you hear a click.
GUID-CE86F073-380E-435D-8743-D823C364C077 v2
October 2026
