WARNING
All route and navigation lines displayed on the chartplotter are only intended to provide general route guidance or to identify proper channels, and are not intended to be precisely followed. Always defer to the navaids and conditions on the water when navigating to avoid groundings or hazards that could result in vessel damage, personal injury, or death.
WARNING
The Auto Guidance feature is based on electronic chart information. That data does not ensure obstacle and bottom clearance. Carefully compare the course to all visual sightings, and avoid any land, shallow water, or other obstacles that may be in your path.
WARNING
When using Go To, a direct course and a corrected course may pass over land or shallow water. Use visual sightings, and steer to avoid land, shallow water, and other dangerous objects.
NOTE:
Auto Guidance is available with premium charts, in some areas.
Before you can navigate to a waypoint, you must create a waypoint.
Select .
To browse the list, use the
arrow keys to highlight the list and press SELECT.
Select a waypoint.
Select
Navigate To.
Select an option:
To navigate directly to the location, select
Go To.
To create a route to the location, including turns, select
Route To.
To use Auto Guidance, select
Auto Guidance.
Review the course indicated by the magenta line.
NOTE:
When using Auto Guidance, a gray segment within any part of the magenta line indicates that Auto Guidance cannot calculate part of the Auto Guidance line. This is due to the settings for minimum safe water depth and minimum safe obstacle height.
Follow the magenta line, steering to avoid land, shallow water, and other obstacles.
NOTE:
In the center of the magenta line is a thinner purple line that
represents the direct course from your current location to your
destination. The direct course is dynamic, and it moves with your boat
when you are off course.
