Customizing a Button
  1. From the Garmin PowerSwitch™ app screen, select Edit field.
    The app enters editing mode.
  2. Select Edit field on the button you want to customize.
  3. Select an option:
    • To change the name of the button, select the Button Label field, and enter a name.
    • To add an icon to the button, select the Icon field, and select an icon.
    • To change the button color, select a color.
    • To change the button mode, select a button mode.
    • To adjust the intensity of the switch, use the slider.
    • To set the button to activate with a control input, select a control input.
  4. Select Back.
  5. Select Done.
Copyright © Garmin. All rights reserved.GUID-CA7AA54D-CB83-4144-9D67-F6EFCC67D442 v8
