Turning On the Device Manually
Before you turn on the device using battery power, you should fully charge the battery.
NOTE:
When the device is connected to an ignition-switched power outlet, it turns on automatically when you turn on the vehicle.
Select
The device turns on.
Parent Topic: Getting Started
