Tips for Pairing Wireless Sensors
  • Verify that the sensor is compatible with your Garmin® device.
  • Before you pair the sensor with your Garmin device, move 10 m (33 ft.) away from other sensors with ANT‍+® technology.
  • Bring the Garmin device within range 3 m (10 ft.) of the sensor.
  • After you pair the first time, your Garmin device automatically recognizes the sensor each time it is activated. This process occurs automatically when you turn on the Garmin device and only takes a few seconds when the sensors are activated and functioning correctly.
  • When paired, your Garmin device receives data from only your sensor, and you can go near other sensors.
Copyright © Garmin. All rights reserved.GUID-C450309A-173E-4C78-AA63-EE2DC944A3C3 v1
