Downloading Maps
Before you can download maps to your device, you must connect to a wireless network (Connecting to a Wireless Network).
Select
Map Manager > Outdoor Maps+.
NOTE: You may need to add this application to the main menu before you can select it.
Select an option:
To download free satellite map data without a subscription, select Add Satellite Imagery.
To download premium maps and activate your Outdoor Maps+ subscription for this device, select Check Subscription.
NOTE: Go to garmin.com/outdoormaps for information about purchasing a subscription.
Select
> Layer Information to view details about the map layers (optional).
- Select Add.
From the map, complete one or more actions:
Drag the map to view different areas.
Pinch or spread two fingers on the touchscreen to zoom in and out of the map.
Select
and
Double-tap the map to quickly zoom in.
- Select the information bar at the top of the screen.
- Select Name to edit the name of the map download.
- Select Storage Location to change where you want to download and store the map.
Select a toggle switch to enable or disable map layers.
An estimated download size appears for the map. You should verify your device has enough available storage space for the map.
TIP: You can tap the name of a map layer for more information about the map data. -
Select
> Download.
Parent Topic: Managing Maps
