Calibrating the Barometric Altimeter
You can calibrate the barometric altimeter manually if you know the correct elevation or the correct barometric pressure.
  1. Go to a location where the elevation or barometric pressure is known.
  2. Select Track Manager > My Track > Elevation plot > Menu > Altimeter Setup > Calibrate Altimeter.
  3. Follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-C450309A-173E-4C78-AA63-EE2DC944A3C3 v1
