Getting Started
You can use the Varia™ Rearview Radar RTL515/RTL516 with your compatible Garmin® device, a smartphone, or the Varia RDU (radar display unit). This list provides an overview of the installation and setup tasks.
- Charge the device (Charging the Device).
- Install the universal mount (Installing the Universal Mount).
- If you are using an Edge® 1030 device, pair the devices ( The Varia RTL515/RTL516 and Your Edge 1030).
- If you are using your smartphone, download the Garmin Varia app to your smartphone, and pair the devices (The Varia RTL515/RTL516 and the Varia App).
- If you are using the Varia RDU, pair the devices ( The Varia RTL515/RTL516 and Your Radar Display Unit).
- If you are using another Garmin device, pair the devices (Other Compatible Devices).
Parent Topic: Introduction
