Setting the Water Temperature Offset
You can set the temperature offset to compensate for the temperature reading from a temperature-capable sensor.
  1. Measure the water temperature using the temperature-capable transducer that is connected to the device.
  2. Measure the water temperature using a different thermometer or temperature sensor that is known to be accurate.
  3. Subtract the water temperature measured in step 1 from the water temperature measured in step 2.
    This is the temperature offset. Enter this value in step 5 as a positive number if the sensor connected to the device measures the water temperature as being colder than it actually is. Enter this value in step 5 as a negative number if the sensor connected to the device measures the water temperature as being warmer than it actually is.
  4. Select Settings > My Vessel > Temp. Offset.
  5. Use the arrow keys to enter water temperature offset measured in step 3.
GUID-C3C9935A-44AD-4A64-8690-B6176625C6BC v4
March 2025
