Controls
The controls menu lets you quickly access watch features and options. You can add, reorder, and remove the options in the controls menu (Prispôsobenie ponuky ovládacích prvkov).
Icon |
Name |
Description |
ABC |
Select to open the altimeter, barometer, and compass app. |
Režim v lietadle |
Select to enable or disable airplane mode to turn off all wireless communications. |
Budík |
Select to open the alarm clocks app (Nastavenie budíka). |
Alternatívne časové zóny |
Select to view the current time of day in additional time zones (Pridanie alternatívnych časových pásiem). |
Výškomer |
Select to open the altimeter screen. |
Pomocník |
Select to send an assistance request (Žiadosť o pomoc). |
Barometer |
Select to open the barometer screen. |
Šetrič batérie |
Jas |
Select to adjust the screen brightness (Nastavenia displeja a jasu). |
Odoslať srdcový tep |
Select to turn on heart rate broadcasting to a paired device (Prenos údajov srdcového tepu). |
Kalkulačka |
Select to use the calculator, including the tip calculator. |
Kalendár |
Select to view upcoming events from your phone calendar. |
Ovládanie kamery |
Select to manually take a photo and record a video clip on a compatible Varia™ headlight (Používanie ovládacích prvkov kamery Varia). |
Hodiny |
Select to open the Hodiny app to set an alarm, timer, stopwatch, or view alternate time zones (Hodiny). |
Kompas |
Select to open the compass screen. |
Zobraziť |
Select to turn off the screen for alerts, gestures, and Stále zapnutý displej mode (Nastavenia displeja a jasu). |
Nerušiť |
Select to enable or disable do not disturb mode to dim the screen and disable alerts and notifications. For example, you can use this mode while watching a movie. |
Nájsť môj telefón |
Select to play an audible alert on your paired phone, if it is within Bluetooth® range. The Bluetooth signal strength appears on the Venu® X1 watch screen, and it increases as you move closer to your phone. Select to navigate to your lost phone during a GPS activity (Lokalizácia telefónu, ktorý sa stratil počas aktivity GPS). |
Garmin Share |
Select to open the Garmin Share app (Garmin Share). |
História |
Select to view your activity history, records, and totals. |
Uzamknúť zariadenie |
Select to lock the buttons and the touchscreen to prevent inadvertent presses and swipes. |
Messenger |
Select to open the Messenger app (Aplikácia Garmin Messenger). |
Hudba |
Select to control music playback on your watch or phone. |
Upozornenia |
Select to view calls, texts, social network updates, and more, based on your phone notification settings (Povolenie upozornení z telefónu). |
Telefón |
Select to enable or disable Bluetooth technology and your connection to your paired phone. |
Asistent telefónu |
Select to connect to your phone's voice assistant (Používanie asistenta telefónu). |
Vypnúť |
Select to turn off the watch. |
Pulzový oxymeter |
Select to take a manual pulse oximeter reading (Ako získať údaje z pulzového oxymetra). |
Režim Red Shift |
Select to turn the screen to shades of red to use the watch in low light conditions. |
Referenčný bod |
Select to set a reference point for navigation (Nastavenie referenčného bodu). |
Uložiť polohu |
Select to save your current location to navigate back to it later. |
Nastavenia |
Select to open the settings menu. |
Režim spánku |
Select to enable or disable Režim spánku, set a nap timer, and manually track your naps. |
Stopky |
Select to start the stopwatch. |
Stroboskop |
Select to turn on the LED flashlight strobe. You can create a custom strobe mode (Úprava vlastného nastavenia stroboskopu). |
Východ & západ slnka |
Select to view sunrise, sunset, and twilight times. |
Synchronizovať |
Select to sync your watch with your paired phone. |
Synchronizácia času |
Select to sync your watch with the time on your phone or using satellites. |
Časovač |
Select to set a countdown timer. |
Dotykový zámok |
Select to enable swiping down from the top of the screen to unlock the touchscreen. |
Hlasový asistent |
Select to connect to voice assistance (Používanie asistenta telefónu). |
Hlasový príkaz |
Select to open the voice command app and say a command (Používanie hlasových príkazov). |
Hlasové poznámky |
Select to open the voice notes app and record a note (Zaznamenanie hlasovej poznámky). |
Hlasitosť |
Select to open the watch volume controls. |
Peňaženka |
Select to open your Garmin Pay™ wallet and pay for purchases with your watch (Garmin Pay). |
Vytlačenie vody |
Select to play tones to eject water from the speaker and microphone ports. |
Počasie |
Select to view the current weather forecast and current conditions. |
Wi-Fi |
Select to enable or disable Wi‑Fi® communications. |
