Calibrating the Compass Manually
NOTICE
Calibrate the electronic compass outdoors. To improve heading accuracy, do not stand near objects that influence magnetic fields, such as vehicles, buildings, and overhead power lines.
The watch uses automatic calibration by default. If you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes, you can manually calibrate the compass.
  1. From the watch face, swipe left.
  2. Select Settings > System > Compass > Calibrate.
  3. Move your wrist in a small figure eight motion until a message appears.
September 2026
