Tips for Swimming Activities
  • Before you start swimming, check the activity settings (Activity Settings).
    For example, the touch lock setting is enabled by default for swimming activities.
  • Press Line drawing of the watch with a bottom button callout to record an interval during open water swimming.
  • Before starting a pool swimming activity, follow the on-screen instructions to select your pool size or enter a custom size.
    The watch measures and records distance by completed pool lengths. The pool size must be correct to display accurate distance. The next time you start a pool swimming activity, the watch uses this pool size. You can scroll down to select the activity settings, and select Pool Size to change the size.
  • For accurate results, swim the entire pool length, and use one stroke type for the entire length. Pause the activity timer when resting.
  • Press Line drawing of the watch with a bottom button callout to record a rest during pool swimming (Swim Auto Rest and Manual Rest).
    The watch automatically records swim intervals and lengths for pool swimming.
  • To help the watch count your lengths, use a strong push off the wall and glide before your first stroke.
  • When doing drills, you must either pause the activity timer or use the drill logging feature (Training with the Drill Log).
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
