My device is in recovery mode
Recovery mode options appear on the device when it cannot resolve a software issue.
Select one or more recovery mode options:
Recovery attempt symbol Attempt Recovery
Attempt Recovery: This is the most common solution to repair a software issue. In most cases, you won't lose any activity data.
Recovery help symbol Help
Help: You scan the QR code to access the latest troubleshooting information from Garmin® Product Support.
Recovery cancel activity symbol Cancel Activity
Cancel Activity: If you are currently recording an activity, this cancels the activity.
NOTICE
The current activity data is deleted.
Recovery delete maps symbol Delete Maps
Delete Maps: Removes the maps from the device.
NOTICE
This deletes the map files from your device. When you have access to your computer, you can use the Garmin Express™ application to restore the map files.
Recovery computer plug symbol Connect to Computer
Connect to Computer: When you have access to your computer, you can use the Garmin Express application to update the software.
Recovery factory reset symbol Factory Reset
Factory Reset: Restores the device to the factory defaults.
NOTICE
This deletes all user data, settings, and pairing information. Any data that has been synced to your Garmin Connect™ account can be restored.
Power off symbol Power Off
Power Off: Turns the device off.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
