Receiving Data with Garmin Share
Before you can use this feature, you must have Bluetooth® technology enabled on both compatible devices, and they must be within 3 m (10 ft.) of each other. When prompted, you must also consent to share your data with other Garmin® devices using Garmin Share.
  1. From the watch face, swipe left.
  2. Select Garmin Share.
  3. Wait while the device locates compatible devices in range.
  4. Select Checkmark symbol.
  5. Confirm the six-digit PIN matches on both devices, and select Checkmark symbol.
  6. Wait while the devices transfer the data.
  7. Select Done.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v4
June 2026
