Downloading Maps with Outdoor Maps+
Before you can download maps to your device, you must connect to a wireless network (Connecting to a Wi‑Fi Network).
  1. From the watch face, swipe left.
  2. Select Settings > Map & Navigation > Map Manager > Outdoor Maps+.
  3. If necessary, press Line drawing of the watch with a top button callout, and select Check Subscription to activate your Outdoor Maps+ subscription for this watch.
    NOTE: Go to garmin.com/outdoormaps for information about purchasing a subscription.
  4. Select Add Map, and select a location.
    A preview of the map region appears.
  5. From the map, complete one or more actions:
    • Drag the map to view different areas.
    • Pinch or spread two fingers on the touchscreen to zoom in and out of the map.
    • Select Plus symbol and Minus symbol to zoom in and out of the map.
  6. Press Line drawing of the watch with a bottom button callout, and select Checkmark symbol.
  7. Select Edit symbol.
  8. Select an option:
    • To edit the map name, select Name.
    • To change the map layers to download, select Layers.
      TIP: You can select More information to view details about the map layers.
    • To modify the map region, select Selected Area.
  9. Select Checkmark symbol to download the map.
    NOTE: To prevent battery drain, the watch queues the map download for later, and the download starts when you connect the watch to an external power source.
September 2026
