Recording an Ultra Run Activity
  1. From the watch face, swipe left.
  2. Select Activities > Running > Ultra Run.
  3. Press Line drawing of the watch with a top button callout to start the activity timer.
  4. Start running.
  5. Press Line drawing of the watch with a bottom button callout to record a lap and start the rest timer.
    TIP: You can configure how the Auto Rest setting records rest splits and laps (Ultra Run Auto Rest Settings).
  6. When you are done resting, press Line drawing of the watch with a bottom button callout to resume running.
  7. Swipe up or down to view additional data screens (optional).
  8. After you complete your activity, press Line drawing of the watch with a top button callout, and select Save.
You can customize the options for automatically starting and stopping the rest timer for the Ultra Run activity.
Status
Enables automatically recording rest splits.
Rest Start
Automatically starts the rest timer when you stop running. You can use the Manual Only option to start the rest timer only when you press Line drawing of the watch with a bottom button callout.
Rest End
Sets the pace required to end a rest split.
Minimum Time
Sets the amount of time before a rest split starts or ends.
Lap Key
Sets the Line drawing of the watch with a bottom button callout button to record a lap and start the rest timer, start the rest timer only, or record a lap only.
September 2026
